Terry Raymond
Populate drawing title block with weldment cut list member properties
Discussion created by Terry Raymond on Nov 22, 2014
Latest reply on Sep 23, 2020 by Anup Harak
I figured this out with much help from yall's posts on this forum.  Sharing macro as thanks!  There have been a few posts in the past that didn't arrive at a solution; will point them here.
Let me know if you see a way to improve!
    Dim swSheet As SldWorks.Sheet
    Dim swView As SldWorks.View
    Dim swFeature As SldWorks.Feature
    Dim swBodyFolder As SldWorks.BodyFolder
    Dim swCustPropMgr As SldWorks.CustomPropertyManager
    Dim bool As Boolean
    Dim sViewName, sViewBodyName, sBodyName, sPropVal As String
    Set swDraw = swApp.ActiveDoc
    bool = swDraw.ActivateSheet(swDraw.GetSheetNames(0))
    Set swSheet = swDraw.GetCurrentSheet
    Set swView = swDraw.GetFirstView
    'Find the main referenced view of the document on sheet1.  If default, find the first view.
    If swSheet.CustomPropertyView = "Default" Then
        Do While Not swView Is Nothing
            If (swView.ReferencedDocument Is Nothing) Then
                Set swView = swView.GetNextView 'skip empty sheet "views" etc
            Else
                sViewName = swView.Name
                Exit Do
        Loop
    Else
        sViewName = swSheet.CustomPropertyView
        Do While swView.Name <> sViewName And Not swView Is Nothing
        Loop
    'If no referenced document was found, swView will be empty.  So no use trying to copy variables from a part.
    If swView Is Nothing Then Exit Sub
    Set swModel = swView.ReferencedDocument
    'If it is a view of a single body Weldment Member, get cutlist properties & populate title block
    If swModel.GetType = swDocPART Then
        If swModel.IsWeldment And swView.GetBodiesCount = 1 Then
        sViewBodyName = swView.Bodies(0).GetSelectionId
        sBodyName = Left(sViewBodyName, InStr(sViewBodyName, "@") - 1)
        'Loop thru all features looking for cutlist items
        Set swFeature = swModel.FirstFeature
        Do While Not swFeature Is Nothing
            If swFeature.GetTypeName = "CutListFolder" Then
                Set swBodyFolder = swFeature.GetSpecificFeature2
                'Loop through cutlist looking for body.  Should only be one body, but loop just to be sure.
                For i = 0 To UBound(swBodyFolder.GetBodies)
                    If swBodyFolder.GetBodies(i).Name = sBodyName Then
                        'Body found! This is where the properties are
                        Set swCustPropMgr = swFeature.CustomPropertyManager
                        Exit Do
                Next i
            Set swFeature = swFeature.GetNextFeature
        Loop
    'get custom properties from normal model if weldment info not found
    If swCustPropMgr Is Nothing Then
        Set swCustPropMgr = swModel.Extension.CustomPropertyManager(swView.ReferencedConfiguration)
    sPropVal = swCustPropMgr.Get("PartNumber")
    bool = swDraw.Extension.CustomPropertyManager("").Add2("PartNumber", swCustomInfoText, sPropVal)
    bool = swDraw.Extension.CustomPropertyManager("").Set("PartNumber", sPropVal)
    sPropVal = swCustPropMgr.Get("Description")
    bool = swDraw.Extension.CustomPropertyManager("").Add2("Description", swCustomInfoText, sPropVal)
    bool = swDraw.Extension.CustomPropertyManager("").Set("Description", sPropVal)
    swDraw.EditRebuild3
