5 Replies Latest reply on Nov 23, 2014 6:11 AM by Daniel Andersson
    swEdrawingSaveAll → Change → swEdrawingSaveSelected
    Yong Ning
      swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll
      Help , How to select configuration?
      2010 SolidWorks API Help - swEdrawingSaveAsOption_e Enumeration
      http://help.solidworks.com/2010/english/api/swconst/solidworks.interop.swconst~solidworks.interop.swconst.swedrawingsaveasoption_e.html
      How to save as eDrawomg with API? | SOLIDWORKS Forums
      https://forum.solidworks.com/thread/83351?fromrss=1
      Help with SaveAs in macro | SOLIDWORKS Forums
      https://forum.solidworks.com/message/438548#438548
          • Re: swEdrawingSaveAll → Change → swEdrawingSaveSelected
            Yong Ning
            Tanks your linked Web.
            Hope result is a1,a3 configuration in b.easm file
            Question, Why  follow code,  Save  Single Configuration in b.easm file
                SwApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveSelected
                Str =  "a1\na3"
                SwApp.SetUserPreferenceStringListValue swUserPreferenceStringListValue_e.swEmodelSelectionList, Str
            Hope Save e.easm file → Have a1,a3 configuration
            Sub SaveEdrawing()
              Dim Path, FileName, Str
              Dim sFileName As String, nErrors As Long, nWarnings As Long
              Dim fileConfig As String, fileDispName As String, fileOptions As Long
              Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                Set SwApp = Application.SldWorks
                Set SwModel = SwApp.ActiveDoc
                sFileName = Left(SwModel.GetPathName, Len(SwModel.GetPathName) - 6)
                If SwModel.GetType = swDocPART Then
                   sFileName = sFileName & "eprt"
                ElseIf SwModel.GetType = swDocASSEMBLY Then
                   sFileName = sFileName & "easm"
                ElseIf SwModel.GetType = swDocDRAWING Then
                   sFileName = sFileName & "edrw"
                Else
                   Exit Sub
                Str = SelectionList = "a1\na3"
                SwModel.Extension.SaveAs sFileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
                Daniel Andersson
                Not at the computer.  But I  see that the string is not correct \n is line separator in Visual C/C++.
                Try this for vba:
                str = "a1" & vbNewLine & "a3"
                Not sure what you mean with the added image of the display states. Display states may or may not be linked to configuration. A configuration may have multiple Display states
                    Yong Ning
                    Thank you reply
                    Str ="a1" & chr(10) & "a3"
                    Private Sub ll()
                      Dim ConfArr, Str
                         ConfArr = SwModel.GetConfigurationNames
                         For ii = 0 To UBound(ConfArr)
                           If Not UCase(ConfArr(ii)) Like UCase("*Default*") And Not ConfArr(ii) Like "*配置*" Then
                              Str = Trim(ConfArr(ii)) & Chr(10) & Str
                         Next ii
                         Debug.Print Str
                           sFileName = sFileName & "Eprt"
                           sFileName = sFileName & "Easm"
                           sFileName = sFileName & "Edrw"
                        Else
                           Exit Sub
