To keep it simple, I want to "slowly" show a pin move into a hole. I have a configuration called "out" that has a distance mate that puts the pin completley out of the hole. I have another configuration called "in" that has a coincident mate that puts the pin completly in the hole. At 0 seconds I would like to see "out" and at 4 seconds I would like to see "in". And of course, see the pin move from "out" to "in" over the 4 seconds of time.
The best I can do is to get it to jump from one configuration to the other with no visual movement in between.
Thanks in advance-
Move time bar at 0 sec. Double click on the key for distance and set the value for distance 3". Than move the time bar to 10 sec, for example, and create another key for distance in this point. Double click on key and set the distance value to 0". A blue bar will show between keys. Click on calculate. Hit play to see the results. Solidworks will gradually change the value for that distance from 3" at 0 sec to 0" at 10 sec.
