Seems there should be an Import option in Search.
I would create a search card with that variable as a text box.
Then in Excel, create a space separated list from your drawing number column. This solution would work, just replace the comma with a space. Then all you need to do is copy and paste from Excel into your textbox.
We do this frequently.. it would look something like this:
Once you have the formula typed in... just drag and copy it to the cells below it. You should see your list grow, each part number with space between the next. then copy the long list of the last cell and paste it into the EPDM search.
Hope that helps!
Create a formula in Excel and copy and paste from there.
