2 Replies Latest reply on Dec 4, 2018 8:23 AM by MARCO TULIO RAMOS FILHO
    EPDM API BatchUnlock AddSelection InvalidArg error?
    Tyler Johnson
      New to the EPDM API as we are just now implementing a vault for the first time.  I'm working on a solution for a machine that processes drawing files automatically and need to make sure the machine is checking in all the files it creates.
      I can loop file.unlockFile and check them in individually but the api help specifically states using batchunlock is faster/more efficient.  So I'm trying to use it but I'm stuck on the addselection method.  It's throwing an error and telling me The Parameter Is Incorrect with an invalidarg error code.
      I've tried everything I can think of.  It's not like there's a lot going on and most of this code is copied right from the api help examples.
      What am I missing?
      Imports EPDM.Interop.epdm
      Module Module1
          Sub Main()
              Try
                  Dim batchUnlocker As IEdmBatchUnlock = Nothing
                  Dim fileList As New List(Of String)
                  Dim vault5 As IEdmVault5 = New EdmVault5()
                  Dim vault7 As IEdmVault7 = DirectCast(vault5, IEdmVault7)
                  Dim file As IEdmFile5 = Nothing
                  Dim folder As IEdmFolder5 = Nothing
                  Dim selection() As EdmSelItem = Nothing
                  If Not vault7.IsLoggedIn Then
                      vault7.LoginAuto("Eng Vault", vbNull)
                  batchUnlocker = vault7.CreateUtility(EdmUtility.EdmUtil_BatchUnlock)
                  Using reader As New Microsoft.VisualBasic.FileIO.TextFieldParser("C:\filelist.txt")
                      While Not reader.EndOfData
                          fileList.Add(reader.ReadLine)
                      End While
                      reader.Close()
                  End Using
                  If fileList.Count = 0 Then
                      Exit Sub
                  Else
                      Array.Resize(selection, fileList.Count)
                      Dim i As Integer = 0
                      For Each filePath In fileList
                          file = vault7.GetFileFromPath(filePath, folder)
                          selection(i).mlDocID = file.ID
                          selection(i).mlProjID = folder.ID
                          i = i + 1
                      Next
                      batchUnlocker.AddSelection(vault5, selection)
                  batchUnlocker.CreateTree(vbNull, EdmUnlockBuildTreeFlags.Eubtf_MayUnlock)
                  fileList = batchUnlocker.GetFileList(EdmUnlockFileListFlag.Euflf_GetUnlocked)
                  batchUnlocker.UnlockFiles(vbNull)
              Catch ex As Exception
                  MsgBox(ex.Message)
              End Try
      End Module
