I’ve created a sketch line in a solidworks part. Open composer
and imported the part/assembly into composer.Now I want to take a component in
composer and let the component move, following the line that was created in
solidworks. 2 questions, how do I import the sketch lines into composer as
well, and second question can you then select the line for “create path from
line (linear speed)” found under animate> paths.
I know it can be done in SW but would like to do it in Composer.
jaco
Jaco,
Unless there is a work around I am unaware of Composer is not going to import a sketch only. For the second part of your question you can set your animation up in Composer using paths but you will need to create the path in Composer. This shouldn't take you long to create the path from your image in Composer.
Cheers,
Derek
