1 Reply Latest reply on Nov 20, 2014 1:11 PM by Yijin Mao
    why this simple macro draw a wrong point while the coordinates are correct?
    Yijin Mao
      Option Explicit
      Dim Part As Object
      Dim boolstatus As Boolean
      Const depth As Double = "150e-3"
      Const H As Double = "12.7e-3"
      Const L As Double = "6e-3"
      Const ratioH As Double = "0.3"
      Const ratioL As Double = "0.5"
      Const ratioHGap As Double = "0.2"
      Dim H1 As Double
      Dim L1 As Double
      Dim H2 As Double
      Dim L2 As Double
      Dim P4x As Double, P4y As Double, P4z As Double
      Dim P5x As Double, P5y As Double, P5z As Double
      Dim P6x As Double, P6y As Double, P6z As Double
      H1 = ratioH * H
      L1 = ratioL * L
      H2 = (1 - ratioH - ratioHGap) * H
      L2 = L1 * H2 / (H - H1)
      P4x = L
      P4y = H2
      P4z = 0
      P5x = L - L2
      P5y = H2
      P5z = 0
      P6x = L
      P6y = 0
      P6z = 0
      ' use your own template
      Set Part = swApp.NewDocument("C:\ProgramData\SolidWorks\SolidWorks 2013\templates\Part.prtdot", 0, 0, 0)
      swApp.ActivateDoc2 "wedgelockPart2", False, longstatus
      Set Part = swApp.ActiveDoc
      Dim myModelView As Object
      Set myModelView = Part.ActiveView
      myModelView.FrameLeft = 0
      myModelView.FrameTop = 21
      myModelView.FrameWidth = 1291
      myModelView.FrameHeight = 585
      boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 5, False, 0, Nothing, 0)
      Part.SketchManager.InsertSketch True
      Part.ClearSelection2 True
      Dim skSegment As Object
      ' P4
      Set skSegment = Part.SketchManager.CreateLine(P4x, P4y, P4z, P5x, P5y, P5z)
      ' P5
      Set skSegment = Part.SketchManager.CreateLine(P5x, P5y, P5z, P6x, P6y, P6z)
      ' P6
      Set skSegment = Part.SketchManager.CreateLine(P6x, P6y, P6z, P4x, P4y, P4z)
      ' this two are same
      ' however the real one in the generated drawing is not same
      Debug.Print P4x
      Debug.Print P6x
      boolstatus = Part.Extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
      Part.ShowNamedView2 "*Trimetric", 8
      boolstatus = Part.Extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 4, Nothing, 0)
      Dim myFeature As Object
      Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, depth, depth, False, False, False, False, 0, 0, False, False, False, False, True, True, True, 0, 0, False)
      Part.SelectionManager.EnableContourSelection = False
      Part.ShowNamedView2 "*Front", 1
      Part.ViewZoomtofit2
