I have a complicated part with draft angles on opposite sides that follow a complicated contour. I have been trying to solve the problem for weeks and still don't have I have a complicated part with draft angles on opposite sides that follow a complicated contour. I have been trying to solve the problem for weeks and still don't have a good result. Looking for help with getting the model finished.a good result. Looking for help with getting the model finished. Along the right side if you are looking at the front view there is a 4.5° draft outward, and from the same view on the left side there is a 2.5° draft inward. I've managed to create the basics and get it somewhat there. The problem that I am running into is that the draft angles need to blend with the other edges, the edges that I have no draft angle on are supposed to be 90° and the drafted angles blend into the sections that are not at a draft angle. This has been my nightmare for weeks and I am finally breaking down and seeking help. I've attached the file as it currently is, and am looking for any suggestions that could help me get it somewhere where I can use it.
Was the model created in SW2015? I am on 2014 and can't open it.
