0 Replies Latest reply on Nov 19, 2014 6:48 AM by Manikandan Babu
    Transform
    Manikandan Babu
      How to transform the sketch points to assembly drawing view.
      Sketch points is inside the  part accompanied in assembly.
      Place the block in drawing view with reference to sketch point..
      reference. Below macro is fine for if sketch in front plane. Now I transferred sketch plane from front to top now its not working.. Please help me to resolve this ..otherwise any other suggestion.
      Option Explicit
      Dim swmodel As SldWorks.ModelDoc2
      Dim swsel As SldWorks.SelectionMgr
      Dim swview As SldWorks.View
      Dim swdrw As SldWorks.DrawingDoc
      Dim swfeat As SldWorks.Feature
      Dim swskt As SldWorks.Sketch
      Dim swpt As SldWorks.SketchPoint
      Dim swmath As SldWorks.MathUtility
      Dim swmtrans As SldWorks.MathTransform
      Dim swmpt As SldWorks.MathPoint
      Dim swblk As SldWorks.SketchBlockDefinition
      Dim swblkinst As SldWorks.SketchBlockInstance
      Dim sktmgr As SldWorks.SketchManager
      Dim swdcomp As SldWorks.DrawingComponent
      Dim swcomp As SldWorks.Component2
      Dim vpos As Variant
      Dim fpath As String
      Dim vpt(2) As Double
      Dim vbpt(2) As Double
      Dim vmpt As Variant
      Dim vapt As Variant
      Dim bret As Boolean
      Dim vSkPtArr                As Variant
      Dim vSkPt                   As Variant
      Dim i As Long
      Dim p As Integer
      Dim scaledec As Double
      Dim vRelation As Variant
      Dim count  As Integer
      Dim swSkRel As SldWorks.SketchRelation
      Dim vSkRel  As Variant
      Dim vBlockDef                   As Variant
      Dim vBlockInst                  As Variant
      Dim swBlockDef                  As SldWorks.SketchBlockDefinition
      Dim swBlockInst                 As SldWorks.SketchBlockInstance
      Dim insPt As SldWorks.MathPoint
      Dim vInstPt As Variant
      Dim j As Integer
      Set swmodel = swApp.ActiveDoc
      Set swsel = swmodel.SelectionManager
      Set swdrw = swmodel
      swmodel.DeSelectByID "Sheet1", "SHEET", 0, 0, 0
      Set sktmgr = swmodel.SketchManager
      Set swfeat = swsel.GetSelectedObject5(1)
      Set swskt = swfeat.GetSpecificFeature
      Set swview = swsel.GetSelectedObjectsDrawingView2(1, 0)
      Set swmath = swApp.GetMathUtility
      vpos = swview.Position
      scaledec = swview.ScaleDecimal
      Set swdcomp = swsel.GetSelectedObject5(2)
      Set swcomp = swdcomp.Component
      swmodel.ClearSelection2 True
      swmodel.Extension.SelectByID2 "test", "SUBSKETCHDEF", 0, 0, 0, False, 0, Nothing, 0
      swmodel.EditDelete
      vSkPtArr = swskt.GetSketchPoints2
      For p = 0 To UBound(vSkPtArr)
      Set swpt = vSkPtArr(p)
      Dim swent As SldWorks.Entity
      Dim ep As SldWorks.EdgePoint
      Set ep = swent
      Set swent = ep
      count = swpt.GetRelationsCount
      If count > 0 Then
      vRelation = swpt.GetRelations
      For Each vSkRel In vRelation
      Set swSkRel = vSkRel
      vpt(0) = swpt.X
      vpt(1) = swpt.Y
      vpt(2) = swpt.Z
      '' Sketch Point location in assembly
      Set swmpt = swmath.CreatePoint(vpt)
      Set swmtrans = swcomp.Transform2
      Set swmpt = swmpt.MultiplyTransform(swmtrans)
      vapt = swmpt.ArrayData
      '' Sketch Point location in drawing
      Set swmtrans = swview.ModelToViewTransform
      vmpt = swmpt.ArrayData
      '' Calculate block insert point
      vbpt(0) = (vmpt(0) / scaledec) - (vpos(0) / scaledec)
      vbpt(1) = (vmpt(1) / scaledec) - (vpos(1) / scaledec)
      Set swmpt = swmath.CreatePoint(vbpt)
      fpath = swApp.GetCurrentMacroPathFolder
      swdrw.ActivateView (swview.Name)
      sktmgr.MakeSketchBlockFromFile swmpt, "C:\My data\test\test.SLDBLK", False, 1, 0
      swmodel.GraphicsRedraw2
      swview.SelectEntity swent, False
      Next
      Next p
      'Add the relation
      vBlockDef = sktmgr.GetSketchBlockDefinitions
          If Not IsEmpty(vBlockDef) Then
              For i = 0 To UBound(vBlockDef)
                  Set swBlockDef = vBlockDef(i)
      vBlockInst = swBlockDef.GetInstances
      Dim k As Integer
      k = 0
      If Not IsEmpty(vBlockInst) Then
      For j = 0 To UBound(vBlockInst)
      Set swBlockInst = vBlockInst(j)
      Set insPt = swBlockDef.InsertionPoint
      vInstPt = insPt.ArrayData
      swmodel.Extension.SelectByID2 "Insertion Point/" & swBlockInst.Name, "SKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0
      swmodel.SketchAddConstraints "sgCOINCIDENT"
      swmodel.ForceRebuild3 True
      k = k + 1
      Next j
      Next i
      MsgBox ("Completed")
