I'm having trouble with the curvature using boundary surfaces. I'm new to surfacing and therefore I'm not sure how efficiently I'm doing it, but regardless I can't figure out this issue I'm having.
http://i.imgur.com/hg0y6Re.jpg
As you can see, for the most part the surfaces all smoothly blend into one another, but there is an anomalous red line cutting through the model that I need to get rid of. I'm using the end of each boundary as a direction guide and ordering them all to be tangent to each other but the surfaces just won't work together.
Is there a way for me to fix it?
I believe it all stems from the profile in Sketch1. One of the curves that meets at that point has a quick change in curvature right near that point, so the boundary surfaces have a hard time following that edge, and it results in weird curvature right there. I suspect if that is smoothed out then the surfaces will improve.
