Has anyone had problems with SW rebuilding a model (the
samemodel)within an assembly 6 times or more in a row before it
finallyfinishes? What about SW ALWAYS rebuilding the model
from thebeginning (not in assy mode) irregardless of what was
changed inthe feature tree?
I thought one of the earlier releases (2001-2002?) change therebuild code that the model would only rebuild the feature affectedby a change. Was this implemented? If so, is theresomething I need to turn on to get this feature?
I've literally got 3 full days of down time waiting for a modelI've been working on for the past week. A rebuild on thisthing (irregardless of the change) takes 15-20 minutes as itsrebuilding the file so many times.
Is there anyway to shut down assembly rebuilding? Unfortunately, I need to work in the assembly to create thegeometry around some parts. I've tried rebooting thecomputer, restarting SW, etc, etc etc.
I'm running XPpro SP2, SW SP3, a gig of ram (probably a little low,but that's what I've got) and a 3.0 HT intel.
Sorry, partially venting here. I'm really close to chuckingthe whole works into the lake and finishing up my design work witha stone tablet and chisel. It would be faster.
Any help is greatly appreciated. Thanks
Joe
Joe
I have found the following may contribute to long rebuild times on complex assemblies:
1. In-context relationships
2. Large number of top level mates.
3. Multiple configurations, especially when said configurations are represented in an open drawing file.
Solidworks allows you to achieve the same results many different ways. It is sometimes possible to paint yourself in a corner. I have quite a bit of experience in that area myself.
