Hi.
I want to save multiple weldments into a single part and keeping the link without combining them first. Is that possible?
I have modelled this with weldments, and the large beams are aluminium which is bolted to the center steel cross.
What is the easiest way of creating a two (three) files?
Save the two large main profiles to two files, and keep the center X?
thanks
1. You can make evertying in one part involving beams and you can also model the rest in the same part.
2. You can make evertying in one part involving beams and you can make the plates in diifernt parts. After that you go to your first part with the beams and do insert part into part, locate parts with move body command and choose constraints wehre you can mate them in.
