NBNikolay Bratovanov18/11/2014
I created a robot arm assembly which must have 500 degrees range of motion. To restrict its rotation I do the following:
- Select Advanced Mates > Limit Angle Mate.
- Choose the mid-plane of the arm and the mid-plane of the body of the robot.
- Set "Angle" to 0, "Max Value" to 250 and "Min Value" to -250.
- Press "OK"
When I start rotating the arm, it makes a 250 degrees rotation and when I rotate it the other way it stops at 110 degrees (the total range of motion becomes 140 degrees) . Then I see that the Limit mate has changed its values to Angle = 110deg; Max.value = 250deg; Min.value = 110deg;
Can you help me solve this problem? Is it possible to limit rotary motion greater than 360 degrees by using Limit mates?
Thank you!
