Feature tree traversal w/ dimension retrieval
Question asked by Dmitry Zamoshnikov on Nov 16, 2014
Latest reply on Nov 16, 2014 by Dmitry Zamoshnikov
I was looking for a way to get a dimension by name through c# and I can't seem to find one.  I'm guessing I can create another function that traverses through each dimension in the feature and search for the dimension by name.  Then I can go through each sub-feature and traverse through each dimension until I find the name I'm looking for.  Does the solidworks API have a dimension by name retrieval function?
This is how I'm looking for the dimension in question:
                // convert the component to a model document
                swSelMod = (ModelDoc2)swCom.GetModelDoc2(); // select the model document of the object
                if (GetFeature(swSelMod, __FEATURE_NAME) != null)
                    swFeat = GetFeature(swSelMod, __FEATURE_NAME);
                    swDispDim = (DisplayDimension)swFeat.GetFirstDisplayDimension();
                    // note: if i want to get the sketch of the feature I just found, I would have to call
                    //  swFeat.GetFirstSubFeature();
                    // this will be a pointer to the sketch.  From there I can find the dimensions of the geometry.
                    swDim = swDispDim.GetDimension();   // get the first dimension in the feature
                    runningTotal += swDim.Value;    // adds up all of the dimensions
                else
                    TxtBx(ctrTextboxMessage, "Feature not found");
        // this will go through each feature in the model document, gotta get the first feature
        // then traverse through the feature tree by calling feat.GetNextFeature().
        // note: many things are considered features: folders, reference geometry, and etc...
        // one way to find what you're looking for is to find the name of the feature
        public Feature GetFeature(ModelDoc2 model, string fieldName)
            int featCount = model.GetFeatureCount();    // get a head count of features
            Feature feat = (Feature)model.FirstFeature();   // target the first feature
            // traverse through each feature in the feature tree in the model document
            for (int i = 1; i <= featCount; i++)
                if (feat.Name == fieldName) // if the feature name is found, return a pointer to the feature
                    return feat;
                feat = feat.GetNextFeature();   // traverse through each feature in the feature tree
            return null;    // feature not found
Message was edited by: Dmitry Zamoshnikov
