I have two non-intersecting sketches (half circles of different sizes w/ curve towards center of helix) at either end of a helical path and can't seem to keep the sketches normal to the helix as it lofts.
David,
I am in SW2104. I have attached 2 screen shots which illustrate. I added a small circle to your sweep sketch it worked perfectly. I left your sketch visible for help, when sweeping around inside radii if the sketch overlaps itself the software does not know how to handle the overlap. If you were to move your ellipse sketch so that the current vertical line is coincident with the start point of the sweep your profile will work.
I personally use sweeps probably #3 in priority after extrudes and revolves. Hope this helps.
Can you post what you have so far? I'm sure someone can help, but it's tough without seeing the Part. (Click on the text "Use advanced editor" at top right of the Reply box to post files.)
