I'm currently running 2013 and have run into a bit of an annoying issue when using routing. I have created new configurations within the default Solidworks routing parts for pipe, long radius 90 deg inch elbows, and reducers. I have done this for an 18" pipe that is not included by default. The issue I am having is that when I drag and drop the default weld flange into a route and select the (included) 18" flange, it finds the 18" pipe configuration and the 18" reducer configuration but it gives me the error "no matching configurations are available for elbow" I can g select it if I choose to edit the route though. It shows up in the routing library in the routing library manager, and all of the "$PRP@Nominal Pipe Size" properties in the design table are "18inch" Is there any reason why it finds the pipe and not the elbow? Any help is appreciated.
Craig,
It could be of a bunch of reasons but in most cases it would be that there is something in the design table not set up right.
Don't forget to check Diameter@Cpoint1 and Cpoint2 as well as BendRadius@ElbowArc in the elbow part as well as checking the necessary data in the pipe file, namely $prp@pipeidentifier, nominaldiameter@Filtersketch, etc.
As you know as well as I do, if the values aren't exactly identical in pipe and parts then strange things happen.
Hope you find it, have a nice one
Peter
