I am having issues with using the Isolate command when the assembly has cable routes in it. If I isolate some cable routes along with some parts, then edit the cable route, exit editing the route after making changes & then exit edit mode I am dumped out of Isolate mode & back to the full model. Haqving to reselct parts again if I need to Isolate & make further changes.
If I do the same thing with an Assembly that doesn't have routes & close editing I remain in Isolate mode.
Can someone please confirm this happens to them in SW2015 & if it's a regression from SW2014 as I don't think it happened in earlier versions.
