2 Replies Latest reply on Nov 12, 2014 5:12 PM by Nick Hayman
    Tangent Edge Macro Button
    Nick Hayman
      Evening All,
      I would like the code for a button which changes the tangent edges to font, visible and hidden on a selected view.
      So far i have the code which changes the tangent edges to the whole page. See below.
      Also have the code of a recorded macro which doesnt work. See below.
      Can anyone give me the code for a button that changes the tangent edges to font, visible or hidden on a selected view? As with the first code i can then tweak the settings to suit visible, hidden and font. Depending what i require.
      Thankyou to all who helped in the last post.
      Helpful Blogger Macro - Works for whole page (not just selected view).
      Dim swDrawDoc As SldWorks.DrawingDoc
      Dim swView As SldWorks.View
      Dim vSheets As Variant
      Dim vViews As Variant
      Dim lSheetCount As Long
      Dim lViewCount As Long
      Dim iDisplayIn As Integer
          Set swApp = Nothing
          Set swModel = Nothing
          Set swDrawDoc = Nothing
          Set swView = Nothing
          Set swModel = swApp.ActiveDoc
          If swModel Is Nothing Then Exit Sub
          If swModel.GetType = swDocumentTypes_e.swDocDRAWING Then
              ' *** Add / Remove comment mark depending on what settings of tanget edges should be.
              'iDisplayIn = swDisplayTangentEdges_e.swTangentEdgesHidden
              'iDisplayIn = swDisplayTangentEdges_e.swTangentEdgesVisible
              iDisplayIn = swDisplayTangentEdges_e.swTangentEdgesVisibleAndFonted
              Set swDrawDoc = swModel
              lViewCount = swDrawDoc.GetViewCount
              vSheets = swDrawDoc.GetViews
              For lSheetCount = LBound(vSheets) To UBound(vSheets)
                  vViews = vSheets(lSheetCount)
                  For lViewCount = LBound(vViews) To UBound(vViews)
                      vViews(lViewCount).SetDisplayTangentEdges2 (iDisplayIn)
                  Next
              Next
      Recorded Macro which doesnt work
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = _
      Set Part = swApp.ActiveDoc
      Dim myView As Object
      Set myView = Part.SelectionManager.GetSelectedObject3(True)
      myView.SetDisplayTangentEdges2 swDisplayTangentEdges_eswTangentEdgesVisible - DEBUG ERROR
        • Re: Tangent Edge Macro Button
          Daniel Andersson
          If you want to be able to multi-select views I think you have to loop thru the selected objects. This will also sort out selected edges etc etc.. Something like this...
          This macro works with selected views in the active drawing sheet.
              Set swApp = Nothing
                  For i = 0 To swSelMgr.GetSelectedObjectCount2(-1)
                      If swSelMgr.GetSelectedObjectType3(i, -1) = swSelectType_e.swSelDRAWINGVIEWS Then
                              Set swView = swSelMgr.GetSelectedObject6(i, -1)
                             swView.SetDisplayTangentEdges2  (iDisplayIn)
                  Next
                  swModel.ClearSelection2 True
