I am new to the routing add-in, but I am designing an assembly with a lot of electrical harnesses so I'd like to take advantage of this tool. My employer does not use the design library at all, which seems to make routing very difficult. I have a top level assembly with connectors which are already mated. Ideally, I would like to be able to add connection points within the connector part files, then make a harness subassembly which contains only the cable (no connectors). At a minimum, I would like to be able to mate the connectors without dragging and dropping them, even if they have to be in the harness subassembly.
At the moment, I cannot rout between connectors if they are not both in the harness subassembly. If I try to have both connectors in the subassembly, it will not let me mate them since I think they are intended to be mated automatically with the drag and drop from the library.
Does anyone have any tips on how I can make this work?
Thanks!
Matt,
Let me see if I get this right : your employer doesn't use the tool as is meant to be and you have no background in using the tool ?
To use the immortal words of B. Simpson :'Aye Caramba'
Matt, I would strongly suggest to either get the training by your VAR or if that is not an option that you do some self study. The latter is possible even by looking up the subject matter on youtube, which contains lots of nice and detailed help especially for those new to it all. There is ofcourse also the help files, e.g.:
Route Subassembly
If a connector is crimped or sealed to the harness during the manufacture of the harness, you should place the connector in the route subassembly rather than the top-level assembly.
The connector appears on the harness drawing and bill of materials.
If you import a from-to list and the connectors are not in the top-level assembly, the software automatically places the connectors in the route subassembly.
I myself don't use routing for electrical means but for piping so there for I can't help you myself, not being familiar with the harness side of things.
However your questions and the info you provide does make it sound to me as if you are trying to use a screwdriver as a hammer and while you might get the nail into the wood, it won't be pretty nor efficient.
Have a nice one and hang in there.
Peter
