Hi
Anyone know how to solve the problem of the lines behind the main parts when you zooms they appear, they vanish when u approaches, and need to generate a pdf of the draft, and the lines appear in pdf, how to hide these lines?
Hi
If you are using SW14 is the Optimize for thin parts option enabled?
If that doesn't fix it, nor any of the other fixes mentioned, what graphics card & driver do you have?
Run the SolidWorks Rx > Diagnostics tool to check.
