Dear Routing Users...
In SW 2007, any body can explain to me with detail on how to change the Outer Diameter of a wire in Wiring harness ( Routing ).....????
Here is a sample case :
Now, I have OD = 1 mm, then one day I will use more the larger wire, lest say 5 mm. How to do this in routing ?
Any body have a guide / video on how to do this ?
BTW, is there any archive of Routing presentation document on SW World 2007 ?
If yes, I hope any body can share that....
Thank`s for any help.....
-DD
-DD
How are you building your harness?? If you are using multiple wires into a connector, then each time you add the wire it will automatically update the harness diameter. If you have the fix diameter box checked, then it will not update automatically in the Route Properties Screen.
