5 Replies Latest reply on Nov 13, 2014 4:33 AM by Feroz Mahomed
    How to edit macro to change depth of cut
    Feroz Mahomed
      How do I modify the code below so that when a sketch is pre-selected and the macro run the cut extrude must be 1mm deep.
      I want the macro to do what is in Green. The line in red cuts through all.
      Option Explicit
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim swSketchManager As SldWorks.SketchManager
      Dim swSketchSegment As SldWorks.SketchSegment
      Dim swFeatureManager As SldWorks.FeatureManager
      Dim swFeature As SldWorks.Feature
      Dim boolstatus As Boolean
      Dim fileerror As Long, filewarning As Long
      Set swModel = swApp.ActiveDoc
      Set swModelDocExt = swModel.Extension
      Set swFeatureManager = swModel.FeatureManager
      'Set swFeature = swFeatureManager.FeatureCut3(True, False, False, 0, 0, 0.001, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, False, True, True, True, True, False, 0, 0, False)
      Set swFeature = swFeatureManager.FeatureCut3(True, False, False, swEndCondThroughAll, swEndCondBlind, 0.01, 0.01, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, False, True, True, False, False, False, swStartSketchPlane, 0, False)
