Hi Friends,
I am getting following Error while doing Static analysis in the mesh while running. Not when meshing the Assembly.
I am using solidworks 2011 Sp5.0 64 bit. I am getting this error, I tried to fix using reducing mesh tolerance and selecting higher no of Jacobin points. Kindly let me know possible solution. Thanks in Advance.
Regards,
A D Kumar,
EGS Computers India Pvt Ltd,
Fix the geometry and choose the right element type and size. Make sure the file survives ctrl q with vor and no bad imported geometry and checks out with tools check.
