Vb.Addin Missing icons in menu! Why???
Question asked by roberto gennari on Nov 11, 2014
Latest reply on Jun 14, 2015 by Gregor Vitz
Hallo
I have a problem with icons in my Addin, they are missing in menu, like in the attached image.
This is my addin code (it is standard):
#Region"UI Methods"
Sub AddCommandMgr()
        Dim mdGroup As ICommandGroup
      If iBm Is Nothing Then
            iBmp = New BitmapHandler()
Dim thisAssembly As Assembly
        Dim cmdIndex0 As Integer,cmdIndex1 As Integer
        Dim Title As String= "wizard"
        Dim ToolTip As String= "wizard"
Dim docTypes() As Integer = {swDocumentTypes_e.swDocASSEMBLY, _
                                       swDocumentTypes_e.swDocDRAWING, _
                                       swDocumentTypes_e.swDocPART}
        thisAssembly = System.Reflection.Assembly.GetAssembly(Me.GetType())
        Dim cmdGroupErr As Integer= 0
        Dim ignorePrevious As Boolean= False
Dim registryIDs As Object= Nothing
        Dim getDataResult As Boolean = iCmdMgr.GetGroupDataFromRegistry(mainCmdGroupID, registryIDs)
Dim knownIDs As Integer() = New Integer(1){mainItemID1, mainItemID2}
        If getDataResult Then
            If Not CompareIDs(registryIDs, knownIDs) Then 'if the IDs don't
match, reset the commandGroup
                ignorePrevious = True
        cmdGroup =iCmdMgr.CreateCommandGroup2(mainCmdGroupID, Title, ToolTip, "", -1, ignorePrevious, cmdGroupErr)
        If cmdGroup Is Nothing Or thisAssembly Is Nothing Then
                 Throw New NullReferenceException()
cmdGroup.LargeIconList = iBmp.CreateFileFromResourceBitmap("SwTools Sketch wizard.Toolbar_large.bmp", thisAssembly)
cmdGroup.SmallIconList = iBmp.CreateFileFromResourceBitmap("SwTools Sketch wizard.Toolbar_small.bmp", thisAssembly)
cmdGroup.LargeMainIcon = iBmp.CreateFileFromResourceBitmap("SwTools Sketch wizard.MainIconLarge.bmp", thisAssembly)
cmdGroup.SmallMainIcon = iBmp.CreateFileFromResourceBitmap("SwTools Sketch wizard.MainIconSmall.bmp", thisAssembly)
Dim menuToolbarOption As Integer = swCommandItemType_e.swMenuItem Or swCommandItemType_e.swToolbarItem
cmdIndex0 = cmdGroup.AddCommandItem2("CreateCube", -1, "Create a cube", "Create cube", 0, "CreateCube", "", mainItemID1, menuToolbarOption)
cmdIndex1 = cmdGroup.AddCommandItem2("Show PMP", -1, "Display sample property manager", "Show PMP", 2, "ShowPMP", "PMPEnable", mainItemID2, menuToolbarOption)
      cmdGroup.HasToolbar = True
      cmdGroup.HasMenu = True
            cmdGroup.Activate()
        Dim flyGroup As FlyoutGroup
        flyGroup =iCmdMgr.CreateFlyoutGroup(flyoutGroupID, "Dynamic Flyout", "Flyout Tooltip","Flyout Hint", cmdGroup.SmallMainIcon,
cmdGroup.LargeMainIcon, cmdGroup.SmallIconList, cmdGroup.LargeIconList, "FlyoutCallback", "FlyoutEnable")
        flyGroup.AddCommandItem("FlyoutCommand 1", "test", 0, "FlyoutCommandItem1","FlyoutEnableCommandItem1")
        flyGroup.FlyoutType = swCommandFlyoutStyle_e.swCommandFlyoutStyle_Simple
        For Each docType As Integer In docTypes
            Dim cmdTab As ICommandTab= iCmdMgr.GetCommandTab(docType, Title)
            Dim bResult As Boolean
            If Not cmdTab Is Nothing And Not getDataResult Or ignorePrevious Then 'if
tab exists, but we have ignored the registry info, re-create the tab.  Otherwise the ids won't matchup and the tab
will be blank
                Dim res As Boolean= iCmdMgr.RemoveCommandTab(cmdTab)
                               cmdTab = Nothing
            If cmdTab Is Nothing Then
                cmdTab = iCmdMgr.AddCommandTab(docType, Title)
                Dim cmdBox As CommandTabBox= cmdTab.AddCommandTabBox
                Dim cmdIDs(3) As Integer
                Dim TextType(3) As Integer
                cmdIDs(0) =cmdGroup.CommandID(cmdIndex0)
                TextType(0) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                cmdIDs(1) =cmdGroup.CommandID(cmdIndex1)
                TextType(1) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                cmdIDs(2) = cmdGroup.ToolbarId
                TextType(2) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                bResult =cmdBox.AddCommands(cmdIDs, TextType)
                Dim cmdBox1 As CommandTabBox= cmdTab.AddCommandTabBox()
                ReDim cmdIDs(1)
                ReDim TextType(1)
                cmdIDs(0) = flyGroup.CmdID
                TextType(0) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextBelow
                bResult = cmdBox1.AddCommands(cmdIDs, TextType)
                cmdTab.AddSeparator(cmdBox1,cmdIDs(0))
        Next
     thisAssembly = Nothing
