I have noticed (after upgrading to 2015) that when I dimension a circle it has <mod - diam> before the required dimension.
Normal linear dimensions are ok.
How do I stop this showing when dimensioning circles.
If I use the insert model dimension function, this additional info also come in.
This has only started to happen in 2015.
Mark
SolidWorks 2015 (sp0)
Hi Mark,
The default location is here > C:\ProgramData\SolidWorks\SOLIDWORKS 2015\lang\english
I've attached the default gtol.sym file for you as well in case yours is lost, deleted, or corrupted for some reason.
Jody
