I want to know if is possible that design table to drive
thenumber of instance on to a circular pattern feature. For
example:to have 6 instances in one configuration and 8 or 12 in
toother...
Sure....create the pattern like you normally would. Then
double click the pattern to see it dimensions....one is the number
of instances. Select it and select the "More Properties" button at
the bottom of the Property Manager.
There you can rename it something like "Number". Then you can copy
the full dimension name (e.g. Number@CirPattern1) to a column in
your design table and control the number.
There you can rename it something like "Number". Then you can copy the full dimension name (e.g. Number@CirPattern1) to a column in your design table and control the number.
Good Luck.
