I am familiar with PDM WORKS Workgroup. This question is in
reference to PDM WORKS Enterprise. I understand they may function
slightly different.
Can anyone tell me if you can put an assembly in one folder inside the PDM Enterprise environment, then put a part file in another folder within the PDM Enterprise environment, then put another part file belonging to that assembly into a completely separate folder inside the PDM enterprise environment?
I am not talking about putting the entire assembly into one file folder and then also putting that file (which becomes a link to the original file location) in another folder because you've used it in another assembly. I am talking about placing these files in seperate folders at initial check-in. Specifying a seperate folder for each part file at initial file check in.
If you can put these files in seperate folder, will PDM recognize the part file path when someone tries opening the assembly or will it give an error message because it cannot find the part?
My guess is that it will find the referenced part and there will be no problems. Just wanted input from others on their experience with this.
Thanks!
Thanks!
If you split off the components as you add the assembly, youwill get a message stating that SolidWorks cannot find the partswhen opening the assembly.
One option is to add the entire assembly and its components inthe same directory, then check the files in, once the files havebeen checked in, move the files to where you want them to go.Another option would be to add the directories to the "ReferencedDocuments" list in the File Locations section of your SolidWorksoptions.
