3 Replies Latest reply on Nov 7, 2014 6:42 AM by Deepak Gupta
    set default dimension size (arrows / font / etc) on sheet to sheet basis in multiple sheet drawing?
    Dave Krum
      Good morning all,
      Not sure if this is possible but thought I'd ask.  I have a simple two sheet drawing where the scales are different on both sheets.  I know how to change the dimensioning size thru options / document properties / dimensions but that propagates thru to all sheets in the document I believe.  Is there a place to set up the dimension sizes (arrows / font height & size / etc) on a sheet to sheet basis so that I don't have to edit each dimension on the second sheet to adjust size that is being used from the default size set thru options?  I'm still on SW2010.  Thanks in advance
