1 Reply Latest reply on Nov 10, 2014 11:01 PM by Vladas Sidlauskas
    API to rotate linear diameter dimension
    Vladas Sidlauskas
      Is there any way to rotate a linear diamer dimension via API? Via GUI this can be done by moving the dot above the dimension.
      Regards,
      Vladas S.
        • Re: API to rotate linear diameter dimension
          Vladas Sidlauskas
          As a workaround, I was able get the rotation by creating the display dimension in the location that gives an angle needed, setting Diametric and DisplayAsLinear properties and setting Annotation position:
          DisplayDimension = Part.AddDimension2(x1, y1, z1)
          DisplayDimension.Diametric = true
          DisplayDimension.DisplayAsLinear = true
          Annotation = this.Reference.GetAnnotation()
          Annotation.SetPosition(x2, y2, z2)
