Is there a way to export a 2D iges file?
I need a 2D vector plot/sketch/part for use in 2D grid generation in Pointwise. I know how to export 2D images in DXF format, but Pointwise doesn't accept DXF. There are a number of file formats it WILL take, and it seems that IGES is the most common. Unfortunately, I can't figure out how to export a 2D IGES file, only 3D. Any ideas?
I have access to a PC with Solidworks 2013.
Thanks!
Maybe you can extrude the sketch as a solid or surfaces and then export the 3D body, then import into Pointwise and just use the starting end of the extrude to get the geometry from.
