i like to add a draft that not begin from edge.
how to do it ?
Why can't you simply use the chamfer command?
You can use rotate face if you don't want to start from edge, you can use split line
Not sure if this is what you are looking for but you can create a split line on the surface you want to draft at Plane 1 and then apply draft to that surface.
