4 Replies Latest reply on Nov 10, 2014 11:35 AM by Lois Claracq
    Debug vb.net add-in without restarting solidworks
    Lois Claracq
      Hello
      Is there a way to build a vb.net add-in without restarting solidworks.
      Currently if Solidworks is started I get "The process cannot access the file '......dll' because it is being used by another process."
      Basically my add-in is a toolbar with multiple separate "macro". I'm trying to find a way to quickly debug each "macro" without having to restart Solidworks each time I make a change.
      Any advice or example is welcome
        • Re: Debug vb.net add-in without restarting solidworks
          Stefan Wozniak
          You can try to uncheck add-in on addins list in SWX and then try to rebuild addin and then check it again. But I'm just guessing.
            Seth Ruhan
            I find that the easiest way when it comes to the actually code debug, is top do it via a VSTA macro.
            Since the code is .net as well. You can directly add Class\Modules into the vsta project as a link (do this by add existing command, then select the arrow next to the add button) .
            Then in the main sub in the VSTA macro make the required calls to the imported calls.
            Any thing to do with the Interface ie add in features, has to be done via the good old restart program\Build
            1 person found this helpful
                Lois Claracq
                Thanks Seth, that's interesting.
                In case someone is interested here is the way I found.
                I went with 2 VS solution and shared VS project. Here is the basic setup
                • Solution : swAddin (this one can only be built when Solidworks is not running)
                  • Project : Class swAddin (add reference to each macro , add reference > Solution > Project > Each macro)
                  • Project : Class/module Macro 1
                  • Project : Class/module Macro 2 ...
                • Solution : Debugger (this one can be build anytime)
                  • Project : Class debugger (add reference to each macro , add reference > Solution > Project > Each macro)
                  • Project : Class/module Macro 1 (shared, add > Existing project ...)
                  • Project : Class/module Macro 2 (shared, add > Existing project ...)
                The main advantage is I can debug my macros line by line directly from visual studio. Although I'm not sure if the way I get the Solidworks object is efficient and if I should add some kind of startup/cleanup routine to avoid memory leak. And I'm not sure if it's related but Solidworks often stays in the task manager even after I close it.
                I noticed in VSTA macro there is a SwMacroSetup and SwMacroCleanup from SolidWorks.Proxy.Sldworks.dll but I could not find any information about those commands
                In case someone is interested or can suggest improvement :
                • Here is the code to launch a macro from the Class swAddin
                     Imports MacroClassXXXXXXX
                        Dim MacroClassObj As Object = New MacroClassXXXXXXX()
                        MacroClassObj.main(SwApp)
                • Here is the code in Class debugger :
                Imports SolidWorks.Interop.sldworks
                Module Module1
                    Sub Main()
                        'Manually get Solidworks Object  for debugging purpose
                        Dim swApp As SldWorks = CreateObject("Sldworks.Application")
                        If swApp Is Nothing Then
                            Exit Sub
                        Else
                            swApp.Visible = True
                        MacroClassObj.main(swApp)
                End Module
