Hello everybody,
I have two quick questions regarding some material data and property settings in non-linear dynamic studies.
1) What is hardening factor?
I've looked around and can't seem to find out what it is or what it does! I found a thread which pointed out it may be related to work hardening, but I'd really like more of a detailed answer of what is is and what its purpose is in nonlinear dynamic simulations.
2) From what I understand, maximum incremental strain is the maximum strain that may occur between time steps during a nonlinear solve, otherwise the time step is reduced and the iteration is repeated to hopefully get a lower strain between steps. Now, this may seem like a dumb question, but is the maximum incremental strain based off engineering strain? i.e (L - Lo)/Lo where L is the stretched length, and Lo is the initial length? Or is it based off logarithmic strain? (Which I don't understand entirely). If anything I'd just like some clarification on how maximum incremental strain works in the nonlinear dynamic simulations. Also, I'd love to know whether increasing its value would be considered a bad idea or not. (i.e leads to poor results).
Thank you for your time!
The Hardening Factor defines the ratio of kinematic to isotropic hardening, where pure isotropic hardening will have a Hardening Factor of 0 while pure kinematic hardening will have a factor of 1. In isotropic hardening the yield surface maintains the same shape and increases in size as the plastic strains increase. In kinematic hardening the yield surfaces maintains the same shape and size and translates around in stress space. Typically, metallic undergo isotropic hardening while plastics and hyperelastic materials undergo kinematic hardening. However, real metals exhibit both isotropic and kinematic hardening, hence the ratio factor.
What strain formulation is used depends on how large the strains are; engineering strain applies to small strains whereas logarithmic strain applies to large strains. I'm not sure whether SW allows the user to control whether engineering or true strain is used, but the safe assumption is to use logarithmic strain (sometimes called true strain).
What exactly do you want to know?
The maximum incremental strain is not something that you typically play around with, as excessively large incremental strains can lead to inaccurate results and/or numerical convergence issues.
