I am having an issue in hole wizard that I have only had since downloading SW15. If I want to locate a hole on a surface, say a tapped hole on a part that is coincident with a counter-bore on a mating part above, when I place the first tapped hole it will allow me to snap to the center of the part above as it should, but it will only do that once. So if I have multiple locations then I have to de-select and then re-select the (*) icon to snap to the next c'bore. Is there a setting off somewhere for this?
This appears to be a bug or regression. It has been mentioned here & other forums.
https://forum.solidworks.com/message/458156?sr=search&searchId=2ca2c3d9-0938-456c-a5a4-6541fc563b84&searchIndex=2#458156
