link drawing ballons from one assembly configuration to a BOM of a different configuration of the same assembly
Question asked by Ryan Leggett on Oct 30, 2014
Latest reply on Nov 3, 2014 by Jamil Snead
Hello and thanks all in advance for your help.
I would like to be able to do the following:
Have one assembly with two configurations. One for the view on the drawing, and a different one for the BOM. An example of this (I can't explain the actual situation I'm working with) would be a structure with a bunch of hardware. The drawing configuration would be everything unsurpressed, and the BOM configuration would be only the hardware. This way I can balloon the hardware items on the view, and by linking that view to the BOM the balloon item numbers should match.
I have successfully done this, but it generally fails after I make any small changes back and forth like the configuration the view looks at, or switch from detailed numbering to flat numbering in the BOM.
My question is, is this a reasonable way of doing this, and is there something I'm doing wrong?
