I would like to show dimples on a dish bottom tank. in other words, how can i linear pattern on a curved surface, because circular pattern will get the features closer to each other towards the center of circular pattern.
Thanks.
Thanks.
Here is something you can maybe work with. Have a look at the file. In the file you can position the dimples exactly where you want on the face and the form of the dimples. Please have a look.
Pattern on normal plane then select sketch and go to Insert - curve- projected. choose face of the tank
I am using SW2013 SP3.
Here is a surfacing approach. I couldn't open Mike's file to see his technique (Future Version).
Like Mike, I found this took a certain amount of brute force. It isn't the cleanest model I've created. But this was an interesting problem. It took several trial and error approaches to get one that worked.
One note regarding the model: The first feature is a Thin Revolve representing the tank followed by a solid. I started with the Thin revolve and later found I wanted the solid but was unable to get rid of the "Thin" setting. Deleting the Thin took all of my associated sketches with it. Being lazy, I just slapped in the solid. If creating from scratch the Thin revolve would not exist.
Daen
You could use linear pattern in a sketch and the wrap feature to bring the pattern on the surface.
