ZCZak Craig30/10/2014
Hi everyone,
I'm currently working with a macro that is going to automatically generate drawings for me based on configurations, but the dimensions are giving me a hard time. Since the parts in the configurations vary widely in size, the dimensions in the drawings are flying all over the place and in many cases off of the sheet.
I want to insert an Auto Arrange Dimensions command in my macro, but I can't seem to find a way to do it. I'm new to macros and the one that I'm using was found on the forums here somewhere.
Here's the macro:
Dim swModel As ModelDoc2
Dim swDrawing As DrawingDoc
Dim configMgr As ConfigurationManager
Dim configs() As String
Dim lErrors As Long, lWarnings As Long
' MAKE SURE YOU CHANGE THE swDocASSEMBLY 4 lines below to swDocPART if you are opening a part not assembly
Dim modelLocation As String: modelLocation = "C:\Users\user\Desktop\Macro Testing\Ball Nose.sldprt"
Dim drawingLocation As String: drawingLocation = "C:\Users\user\Desktop\Macro Testing\Drawings\Ball Nose.SLDDRW"
Dim outputLocation As String: outputLocation = "C:\Users\user\Desktop\Macro Testing\Drawings\Output\"
' Start by opening the files and just presume they open fine else this is a pointless excercise anyway
Set swModel = swApp.OpenDoc6(modelLocation, swDocPART, 0, "", lErrors, lWarnings)
Set swDrawing = swApp.OpenDoc6(drawingLocation, swDocDRAWING, 0, "", lErrors, lWarnings)
' Get all configuration names for this document
configs = swModel.GetConfigurationNames()
' Loop them all
For i = 0 To swModel.GetConfigurationCount() - 1
    ' Activate configuration
    If swModel.ShowConfiguration2(configs(i)) Then
        ' Successfully activated configuration so update model
      '   swModel.ForceRebuild3 True
        ' Now make sure we have the drawing active and update that
        swApp.ActivateDoc2 drawingLocation, True, lErrors
        ' Loop all views and re-reference them
        Dim view As view
        Set view = swDrawing.GetFirstView
        ' Skip first view which is the sheet
        Set view = view.GetNextView
        While Not view Is Nothing
            view.ReferencedConfiguration = configs(i)
            view.UseSheetScale = False
            view.ScaleDecimal = 2  ' 2 = 2:1   0.2 = 1:5 etc... so set it here however you want based on config name which is in configs(i)
        Wend
        ' Update sheet
        swDrawing.ForceRebuild
        ' And save out the drawing
        swDrawing.Extension.SaveAs outputLocation & configs(i) & ".pdf", 0, 0, Nothing, lErrors, lWarnings
Next
Where and how could I insert an Auto Arrange Dimensions command?
