I am having trouble with Electrical 3D Routing of a simple 6-pin to 6-pin harness. I have done a line diagram, reserved a cable, associate wires between the pins & added parts to 3D. Both parts have C-points and I have draw a path. I click on the rout cable nothing happens. I click on it again and click on draw graph it wires appear. Click the check mark and they disappear. Any ideas on this?
I had c-points on the parts for which is only used for wires. I did not have a c-point for Cable. First make a plane off if the connector and sketch a point. Use the electrical components wizard and creat cable connection point from the sketch on the new plan. After that the part is ready to be used for routing cables. Hopes this help anyone that had the same problem.
