How to Show a specific Features Display Dimensions in a Part Document
Question asked by Jacob Corder on Oct 29, 2014
Latest reply on Aug 9, 2017 by Jacob Corder
I am in need of programmatically showing the Display dimensions of a specific feature in a Part Document.
I have tried using selectbyid2,  ISelectionManager.AddSelectionListObject, ISelectionManager.AddSelectionListObjects,
All of the above select the feature, but the feature dimensions do not display the same way if i select it in the Feature Tree.
The features i am trying to Select Programmatically have No Faces.
They are MacroFeatures
They have Display Dimensions
See the attached screenshots.
The Code to do this is:
Sub SelectParentFeature(ByVal ModDoc As ModelDoc2)
        If IsNothing(ModDoc) = False Then
            Dim SelMgr As SelectionMgr = ModDoc.SelectionManager
            Dim SelCt As Integer = SelMgr.GetSelectedObjectCount2(-1)
            If SelCt = 1 Then
                Dim SelFeat As Feature = Nothing
                Select Case SelMgr.GetSelectedObjectType3(1, -1)
                    Case swSelectType_e.swSelFACES
                        Dim ThisFace As Face2 = SelMgr.GetSelectedObject6(1, -1)
                        If IsNothing(ThisFace) = False Then
                            SelFeat = ThisFace.GetFeature
                        ThisFace = Nothing
                    Case swSelectType_e.swSelBODYFEATURES
                        SelFeat = SelMgr.GetSelectedObject6(1, -1)
                End Select
                If IsNothing(SelFeat) = False Then
                        'Get the Parent Feature (Owner Feature)
                         Dim ParFeat As Feature = SelFeat.GetOwnerFeature
                         If IsNothing(ParFeat) = False Then
                             ModDoc.Extension.SelectByID2(ParFeat.Name, "BODYFEATURE", 0, 0, 0, False, -1, Nothing, swSelectOption_e.swSelectOptionDefault)
                             ParFeat = Nothing
                         SelData = Nothing
                         SelFeat = Nothing
                SelMgr = Nothing
All this Sub Does is gets the Selected feature by either SwSelecttype_e.SwSelBodyFeatures or SwSelType_e.SwSelFaces.
then it gets the Owner Feature which is the Feature i want to Show the DisplayDimensions of.
i have tried getting all of the IDisplayDimensions using IFeature.GetFirstDisplayDimension and getting the Annotation from The IDisplayDimension using IDisplayDimension.GetAnnotation
Then Setting the IAnnotation.Visibility to SwAnnotationVisibility_e.swAnnotationVisible which does nothing.
I can make an IAnnotationView and show that but i dont like doing that because it would involve making a new one every time. you cannot name them so getting a special annotationview and clearing the IAnnotations from it seems like too much work. if i have to, i will though.
But i would like to see if there is an easier route.
So Basically all i want to do is show the displayDimensions of a feature without having to select anything.
So Like IFeature.ShowDimensions would be sweet, or something to Achieve this goal
