4 Replies Latest reply on Oct 31, 2014 12:21 AM by Pranjal Jamsandekar
    How do I write the macro for continous fillet as in the attached image ?
    Pranjal Jamsandekar
      Dim swSketchMgr As SldWorks.SketchManager
      Dim swSketchSeg As SldWorks.SketchSegment
      Dim swLine(31) As SldWorks.SketchLine
          Set swModel = swApp.ActiveDoc
          Set swSketchMgr = swModel.SketchManager
          'create plane and insert the sketch
          swModel.Extension.SelectByID2 "TOP PLANE", "PLANE", 0, 0, 0, False, 0, Nothing, 0
          swSketchMgr.InsertSketch True
          'turn on direct addition to database
          swSketchMgr.AddToDB = True
          'create first logo
           Set swLine(0) = swSketchMgr.CreateLine(0.2065, 0.02, 0, 0.1885, 0.02, 0)
           Set swLine(1) = swSketchMgr.CreateLine(0.1885, 0.02, 0, 0.1885, -0.02, 0)
           Set swLine(2) = swSketchMgr.CreateLine(0.1885, -0.02, 0, 0.2065, -0.02, 0)
           Set swLine(3) = swSketchMgr.CreateLine(0.2065, -0.02, 0, 0.2065, 0.02, 0)
         'create second logo
          Set swLine(4) = swSketchMgr.CreateLine(0.1415, 0.02, 0, 0.1235, 0.02, 0)
          Set swLine(5) = swSketchMgr.CreateLine(0.1235, 0.02, 0, 0.1235, -0.02, 0)
          Set swLine(6) = swSketchMgr.CreateLine(0.1235, -0.02, 0, 0.1415, -0.02, 0)
          Set swLine(7) = swSketchMgr.CreateLine(0.1415, -0.02, 0, 0.1415, 0.02, 0)
         'create third logo
          Set swLine(8) = swSketchMgr.CreateLine(0.0915, 0.02, 0, 0.0735, 0.02, 0)
          Set swLine(9) = swSketchMgr.CreateLine(0.0735, 0.02, 0, 0.0735, -0.02, 0)
          Set swLine(10) = swSketchMgr.CreateLine(0.0735, -0.02, 0, 0.0915, -0.02, 0)
          Set swLine(11) = swSketchMgr.CreateLine(0.0915, -0.02, 0, 0.0915, 0.02, 0)
         'create fourth logo
          Set swLine(12) = swSketchMgr.CreateLine(0.0415, 0.02, 0, 0.0235, 0.02, 0)
          Set swLine(13) = swSketchMgr.CreateLine(0.0235, 0.02, 0, 0.0235, -0.02, 0)
          Set swLine(14) = swSketchMgr.CreateLine(0.0235, -0.02, 0, 0.0415, -0.02, 0)
          Set swLine(15) = swSketchMgr.CreateLine(0.0415, -0.02, 0, 0.0415, 0.02, 0)
        'create corner fillet
        Dim i As Integer
         For i = 0 To UBound(swLine)
              Set swSketchSeg = swLine(i)
              swSketchSeg.Select False
              If i = UBound(swLine) Then
                  Set swSketchSeg = swLine(0)
              Else
                  Set swSketchSeg = swLine(i + 1)
              swSketchSeg.Select True
              Set swSketchSeg = swSketchMgr.CreateFillet(0.006, 1)
          Next i
           'turn off direct addition to database
          swSketchMgr.AddToDB = False
      Could anybody please help me to get the fillet continuous as in attached image.
        • Re: How do I write the macro for continous fillet as in the attached image ?
          Daniel Andersson
          I would differentiate each profile by extending the array (to multidimensional) or put each profile in a collection.
          If you use that profile often and repetitive, I would suggest that you make a class (object) of it. The objects could also be in a collection to keep them together. There is also further benefits to use classes (objects). Since you can create your own methods and properties for each profile (width, height, radius, etc.)
              Pranjal Jamsandekar
              Thanks for the reply.
              I will check the method you have explained above.
                  Daniel Andersson
                  Perhaps you already got this going, but I had a few minutes to night to give you this example of using multi-dimensional array.
                  Except from the code below, I would like to tell you a test I did. If you want to increase performance of the code, use swSketchMgr.DisplayWhenAdded = False / True.
                  Please pay attention to the Remarks of this property!
                  Measured the performance difference and got this result:
                  Macro process time [s]: 0.765 (Enabled DisplayWhenAdded)
                  Macro process time [s]: 0.889 (Current code)
                  So there is definitely time to cut here if you have more sketch entities to be added.
                  Dim swLine(3, 3) As SldWorks.SketchLine
                      'create first logo
                       Set swLine(0, 0) = swSketchMgr.CreateLine(0.2065, 0.02, 0, 0.1885, 0.02, 0)
                       Set swLine(0, 1) = swSketchMgr.CreateLine(0.1885, 0.02, 0, 0.1885, -0.02, 0)
                       Set swLine(0, 2) = swSketchMgr.CreateLine(0.1885, -0.02, 0, 0.2065, -0.02, 0)
                       Set swLine(0, 3) = swSketchMgr.CreateLine(0.2065, -0.02, 0, 0.2065, 0.02, 0)
                     'create second logo
                      Set swLine(1, 0) = swSketchMgr.CreateLine(0.1415, 0.02, 0, 0.1235, 0.02, 0)
                      Set swLine(1, 1) = swSketchMgr.CreateLine(0.1235, 0.02, 0, 0.1235, -0.02, 0)
                      Set swLine(1, 2) = swSketchMgr.CreateLine(0.1235, -0.02, 0, 0.1415, -0.02, 0)
                      Set swLine(1, 3) = swSketchMgr.CreateLine(0.1415, -0.02, 0, 0.1415, 0.02, 0)
                     'create third logo
                      Set swLine(2, 0) = swSketchMgr.CreateLine(0.0915, 0.02, 0, 0.0735, 0.02, 0)
                      Set swLine(2, 1) = swSketchMgr.CreateLine(0.0735, 0.02, 0, 0.0735, -0.02, 0)
                      Set swLine(2, 2) = swSketchMgr.CreateLine(0.0735, -0.02, 0, 0.0915, -0.02, 0)
                      Set swLine(2, 3) = swSketchMgr.CreateLine(0.0915, -0.02, 0, 0.0915, 0.02, 0)
                     'create fourth logo
                      Set swLine(3, 0) = swSketchMgr.CreateLine(0.0415, 0.02, 0, 0.0235, 0.02, 0)
                      Set swLine(3, 1) = swSketchMgr.CreateLine(0.0235, 0.02, 0, 0.0235, -0.02, 0)
                      Set swLine(3, 2) = swSketchMgr.CreateLine(0.0235, -0.02, 0, 0.0415, -0.02, 0)
                      Set swLine(3, 3) = swSketchMgr.CreateLine(0.0415, -0.02, 0, 0.0415, 0.02, 0)
                    Dim i As Integer
                  For k = 0 To UBound(swLine, 1)
                       For i = 0 To UBound(swLine, 2)
                          Set swSketchSeg = swLine(k, i)
                          If i = UBound(swLine, 2) Then
                              Set swSketchSeg = swLine(k, 0)
                          Else
                              Set swSketchSeg = swLine(k, i + 1)
                      Next
                  Next
