Hi!
Im having some difficulties with a school project. We need to remake a plant spray.
I've put quite some hours into it, only to come to the realisation i've made some mistakes.
As you can see in the first picture the extrude cut cuts through 3 parts. I only want it to cut to just itself. The problem is, when i delete the other parts in the Feature Scope the whole plant spray seems to collaps in errors as you can see in the second picture.
I have tried everything ( change the end condition etc) nothing worked.
Even when i try to Fully divine a very small part which has nothing to do with the parts that produce an error, i still get errors.
I'm not sure what to do, i cant find any strange Parent/child relations or anything.
Does anyone has any advice?
Just let me know if you need to see more screenshots
Jesse,
While it would be better if you could attach your part so we could better see things, I'll share my thoughts.
It looks like you're editing cut-extrude22, which is upstream of the failing features. It would appear that your cut is removing references and creating multiple bodies, which is causing the model to blow up. Assuming that the cut is as you need it, then you're going to have to just repair each of the failing features one by one.
