I have to make a glove on solidworks, but I have never used it before, I tried to do the basics on solidworks but found it very hard...so I really need some help, I know its a lot of work, but I don't have a choice/
thanks so much! I would appreciate any help)
If you want it to be presented as if a hand is inserted in the glove... there is some hours needed...
My recommendation is that you make sketches of the glove from all sides, top, left, right, bottom. Then you can import these and have as a reference in SolidWorks when you model the glove. My first thought is that you should aim for working with surfaces.... but I might be wrong since I have never worked with products of this type...
You will also most likely need to learn how to project curves to surfaces in order to get all of those lines..
