Hi all,
I'm looking for your help. Hole Wizard has a finite number of predefined hole and slot types and those types have a finite number of options resulting in, yes, you guessed it, a finite number of combinations. I'd like to know what holes/slots you have needed (or continue to need) that you either start with Hole Wizard and then add another feature on to or use other features entirely to create.
There are several Enhancement Requests on the subject that I am aware of:
SPR 534037 - Add standard square holes to hole wizard library
SPR 539727 – Provide ability to link values for near-side and far-side countersink on holes
SPR 543311 – It should be possible to define customized calculations for thread depth in hole wizard
SPR 552146 – In the hole wizard, provide an option 'up to Surface' for Thread termination
SPR 556736 – Ability to create flat bottom holes with the Hole Wizard.
SPR 753353 - Ability to create Hole Wizard slots with flat ( square ) ends
Please provide an image along with your reply so that it is clearly understood what the limitation is that you are running into. Please provide how often you run into this limitation and if the limitation is just for a single size or application of if it is for varying sizes or applications.
Thanks for helping with my research and making the product better.
Jody
