0 Replies Latest reply on Oct 24, 2014 2:17 PM by Nathan Cunningham
    EPDM Search in a web application causing timeout
    Nathan Cunningham
      We currently have Solidworks EPDM 2014 and while we have a few ASP.Net windows applications that run successfully using the EPDM.Interop.epdm and emodel viewer we are try to use the EPDM.Interop.epdm to do searching via a web based ASP.Net application. We are currently using ASP.Net 4.0 and just doing  a basic simple search in the code below. It will run fine through my local without any problems but when I put it out on an actual server it just spins and eventually times out. Yes there is a local EPDM view on the server and it is 2014 just the same as it is on my local machine. Am I missing something here as to why it wont work on a different server?
                      String strPath = "";
                      IEdmSearch5 Search;
                      IEdmSearchResult5 Result;
                      EdmVault5 con;
                      GETEPDMConnection();
                      con = Connection;
                      Search = Connection.CreateSearch();
                      Search.Clear();
                      // Search.FileName = strMachine.ToString();
                      Search.AddVariable("OEM Company", strOEM);
                      Search.AddVariable("OEM Model", strMachine);
                      Search.AddVariable("Part Type", "PLAY");
                      Search.FileName = "%.pdf";
                      Result = Search.GetFirstResult();
                      if (Result != null)
                          String strFile = Result.Path.ToString();
                          if (strFile.Contains("Final Art File"))
                              strPath = Result.Path.ToString();
                      return strPath.ToString();
