Help Required: Pattern around arc with constant HORIZONTAL dimension?
Question asked by Brian Corbin on Oct 23, 2014
Latest reply on Oct 24, 2014 by Jamil Snead
Hi Guys,
So I want to parametrically "Pattern" an object around an arc, but the catch is the constant dimension is in the Horizontal or X-Axis not around the arc. See the attached image.
I will later use some equations to alter the number of patterned objects, or change the horizontal dimension based on the Arc Radius, this I can do, but does anyone have an idea how I can build the Arced pattern with a horizontal dim?
Of course SWX has a pattern "around arc" feature but the constant dim is the distance around the arc not the horizontal dim as I desire. You can see the driven dims show that the distance around the arc is greater for each additional item in the "Pattern"
Maybe there is a simple way to do this? But Im really struggling to be honest to find a solution....
Im on SWX 2014
Thanks guys!
