When using a Hole Series in an assembly I am losing the dimensions that I put into the 3D sketch.
I start the command and the sketch seems to go fine - adding points and dimensions. I close the sketch and the feature seems to build just fine. Some time after that I had to move the part that has the plane that the 3D sketch was on for the Hole Series. I ended up getting rebuild errors. I went and looked at the sketch and the points are out hanging in space with no dimensions on them.
How do I do a Hole Series and maintain the dimensions and relations that are set up?
Edited: Changed sketch type to 3D.
