1 Reply Latest reply on Oct 22, 2014 2:30 PM by Daniel Andersson
    Repetitive Sketch Operation Macro
    Parish Parishram
      Am trying to perform a fillet/ trim-extend operation on a sketch multiple times. When I record a Macro for one such instance, it records the operation with absolute coordinates. Is there a way to record or change the code to relative coordinates? Am thinking i could then just pick a new location and run the Macro each time.
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Arc2507", "SKETCHSEGMENT", 4.88842062031602E-03, 1.17409886110679E-03, 5.00000000000025E-05, True, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Fillet<1>", "SKETCHSEGMENT", 5.16552479057979E-03, 9.9824429151632E-04, 5.00000000000038E-05, True, 0, Nothing, 0)
      Dim skSegment As Object
      Set skSegment = Part.SketchManager.CreateFillet(0.00012954, 1)
      Part.SetPickMode
      boolstatus = Part.Extension.SelectByID2("Arc2507", "SKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
      boolstatus = Part.SketchManager.SketchExtend(4.90973632572092E-03, 1.15811208205311E-03, 0)
      Part.SetPickMode
      boolstatus = Part.SketchManager.SketchExtend(4.96302558923319E-03, 8.91665764491791E-04, 0)
      boolstatus = Part.Extension.SelectByID2("Arc2507", "SKETCHSEGMENT", 4.93105203112583E-03, 7.5844260571113E-04, 5.00000000000054E-05, True, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Fillet<1>", "SKETCHSEGMENT", 5.12822230612121E-03, 8.17060795574621E-04, 5.0000000000005E-05, True, 0, Nothing, 0)
      Part.SetPickMode
      boolstatus = Part.SketchManager.SketchExtend(4.9044073993697E-03, 6.83837636793959E-04, 0)
      Part.SetPickMode
      boolstatus = Part.SketchManager.SketchExtend(4.97901236828687E-03, 9.8225751246264E-04, 0)
      boolstatus = Part.Extension.SelectByID2("Arc2507", "SKETCHSEGMENT", 4.95871782985486E-03, 8.78854032100175E-04, 0, False, 2, Nothing, 0)
      boolstatus = Part.SketchManager.SketchTrim(4, 0, 0, 0)
      boolstatus = Part.Extension.SelectByID2("D4@Sketch1@BVS_3.51_28mm.SLDPRT", "DIMENSION", 4.85644706220866E-03, 8.27718648277073E-04, 5.00000000000049E-05, False, 0, Nothing, 0)
      Part.ClearSelection2 True
      boolstatus = Part.Extension.SketchBoxSelect("0.004761", "0.001057", "0.000000", "0.004894", "0.000833", "0.000000")
      boolstatus = Part.Extension.SelectByID2("D3@Sketch1@BVS_3.51_28mm.SLDPRT", "DIMENSION", 4.89374954666724E-03, 8.27718648277073E-04, 5.00000000000049E-05, False, 0, Nothing, 0)
      Part.EditDelete
      boolstatus = Part.Extension.SelectByID2("D4@Sketch1@BVS_3.51_28mm.SLDPRT", "DIMENSION", 4.89907847301847E-03, 9.2363932259915E-04, 5.00000000000043E-05, False, 0, Nothing, 0)
      Part.EditDelete
        • Re: Repetitive Sketch Operation Macro
          Daniel Andersson
          To record with other coordinates is not possible. You could edit the code you got to use variables and calculate your needed coordinates. Note that the recorded macro also needs to have the same name of the segments as you had during recording in order to work.
          There might be alternative solutions to this, but it is difficult to see since there is no image attached that explains what you do / want to do. I'm thinking in the best case, you do not need, or could extract the coordinates from selected objects instead... etc etc..
          Others might have other ideas to present if you add a principle sketch that explains what you are extending and triming.
