i need to obtain effect of changing a dimension on part in simulation ?
i am designing a crank shaft and i want to analysis effect of changing diameter on endurance.
i know i can change part size and collect result for every size and make chart of results ! but is there any way for doing this automatically ?
Use a "Design Study" and you can vary whatever dimensions/parameters you want.
It's a little much to cover in depth here, but the SW built-in help should set you straight.
Basically in the model tab, do "Insert --> Design Study..." Set your parameters up there.
Then in the simulation tab, you can run a "Design Scenario" in the little "Run" dropdown icon.
I have actually never done this, but know that's how you get started... Good luck!
