I am trying to convert a part to iges. When I do I get the attached error
message. If I click ok it then creates the file, but with a missing surface(s).
I made a forging then inserted it into a new part to make all the cuts. When
I go to save as an iges file, part of a fillet (as forged) disappears. It seems
anything I do, related to cut 12 or even unrelated causes this condition. If I
roll back cut 12 or suppress a feature completed unrelated to cut 12 I get the
same error. To make it even stranger, when I convert the forging there is no
problem. I did notice that the machined version converts as a surface, while
the forging converts as a solid body.
Any help will be greatly approciated.
The machined version makes a surface body in the file conversion because you have faulty faces which are missing in the conversion. Similar to when you select a face on a solid body and deletes it. I would delete the faulty faces and make them again or delete and patch which I also did, trim and knit and make solid again. If you cannot fix them in the referenced part I don´t have.
But here you go. Hope this helps.
