Here is the situation. I create a new part file.
I saveit and the check it into the vault. When I check
it into thevault, I release ownership and delete local copy.
Next, Iopen the same part and take ownership. I make a
change to thepart and then then I try to check it in. The
Check InDocument dialogue box indicates that the part is different
then thecopy in the vault but, doesn't show that it is check
out. I would normally expect the Check in document box to
bechecked. In this case I have to Check the box and then I
getan warning prompt that the local appears to be different...do
youwant over write vault copy.
I don't know what the issue is. BTW-This problem isonly on one machine on our network. Any help would be greatlyappreciated.
